Hi All,
I want to create Prime template for adding Regulatory Domain in WLC's. ( i know this is one time activity but want to create this one for documentation and team training ). but would like to know how to add interactive static response in Cisco Prime CLI template.
Config 802.11b enable network
Are you sure you want to continue? (y/n)
> How to add confirmation as "Yes" in template as this is not a defined command.
Config 802.11a enable network
config countries-list add CH,IN,CN ( for example )
Sharath
