How to check on which APs a wlan profile is activated on WLC4402
we use a wlc4402 and several wlan profiles which are activated on different access-points (wlan override).
Does anybody know if there is a possibility to see a summary list of the aps on which a certain wlan profile is activated?
Best Regards,
Thorsten
Hall of Fame Master
Re: How to check on which APs a wlan profile is activated on WLC
Don't know if you call it a summary, but if you run a show run-config or show running-config on the wlc cli, the ap information is in one of those. You then can paste that to notepad or word and do a find .
-Scott
Highlighted
I tested it but did not get the output I am looking for.
What I am looking for is a list of all wlan profiles and for each wlan profile a list of all ap where it's activated, e.g.:
wlan profile 1
ap1
ap2
ap3
wlan profile 2
ap2
ap5
ap7
Does anybody further know how I can set the cli terminal length to 0 so that there is no page break (as term len 0 in ios)?
Thorsten
Hall of Fame Master
Try config paging enable | disable
-Scott
Rising star
If you have WCS, this can be done under the reporting function
Ask the Expert- Webex Hybrid Services Solutions
