104
sn3 Beginner
Beginner
How to configure monitor mode and coverage on same AP?
Fellow colleagues,
Where can I find guidance on how to properly configure a single, dual-radio, AP so that the 5GHz is serving clients full time while the XOR radio acts as a full-time sensor? We are using a 3504 WLC and our APs are 2802i. If there is any other information that would help this discussion, please let me know.
Many thanks!
2 REPLIES 2
Highlighted
VIP Advocate
Re: How to configure monitor mode and coverage on same AP?
On the WLC go to Wireless - Dual-Band Radios - select the AP and Configure - on the right side, under Radio Role Assignment change to Manual, now you should be able to set it to Monitor.
Tested with 8.8.125.0 and a 2802i.
Contributor
If you are using monitor mode for wIPS with MSE you will also need to set the AP sub mode as wIPS along with setting Flexible radio in static monitor mode.
-Rate helpful posts-
Content for Community-Ad
August's Community Spotlight Awards
