10-01-2014 06:11 AM - edited 07-05-2021 01:37 AM
We have both 1130 and 3500 AP's under the control of a 5508 controller. I have heard that channel "b" can slow down the other AP channels when in the same vicinity.
We have 1130 with channels a/b and 3500 with channels b/g/n. If this in fact does slow down the other channels, how can one globally change this in the 5508?
Thanks.
10-01-2014 02:28 PM
You can do this using WLC GUI.
Under "Wireless -> 802.11b/g/n -> Network -> Disable all data rates 1,2,55,9,11 Mpbs"
Rasika
*** Pls rate all useful responses ****
11-10-2014 08:33 AM
yes this fact is right, you can achieve better performance by disabling the 'b' standard data rates.
11-10-2014 09:06 PM
Please do as advised by other people but please remember this would reduce the cell size and might impact if there was any wireless survey done earlier using low data rates. Second thing is that any client which supports only "b" will not be able to connect (most support b/g though). and third when you disable low data rates namely "b" data rates, Please make sure that at least one higher data rate (above 11 Mbps) is configured as mandatory or else clients would not connect.
Dhiresh
**Please rate helpful posts**
11-24-2014 09:10 AM
Specify the rates at which data can be transmitted between the controller and the client by entering this command:
config {802.11a | 802.11b} rate {disabled | mandatory | supported} rate
where
•disabled—Clients specify the data rates used for communication.
•mandatory—Clients support this data rate in order to associate to an access point on the controller.
•supported—Any associated clients that support this data rate may communicate with the access point using that rate. However, the clients are not required to be able to use this rate in order to associate.
•rate—The rate at which data is transmitted:
–6, 9, 12, 18, 24, 36, 48, and 54 Mbps (802.11a)
–1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, or 54 Mbps (802.11b/g)
Source: http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_controller_setting.html#wp1265208
