111
Highlighted
how to extract report of all accesspoint Login Credentials setting
i want to extract the details of all associated access points login credentials (Over-ride Global credentials)
report from cisco prime infrastructure 3.5
2 REPLIES 2
Re: how to extract report of all accesspoint Login Credentials setting
Hi @chetankumar1542 ,
There is no option to export the credentials of AP via Cisco Prime. If you want to change on all the WLC, You can do it via Prime by creating template (Refer: Community Thread).
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Thanks @Sathiyanarayanan Ravindran it really works
Content for Community-Ad
June's Community Spotlight Awards
