1251
Highlighted
Beginner
How to run setup script again on Prime Infrastructure 2.2 Appliance
Does anyone know how to re-run the setup script on a PI2.2 (UCS) appliance after it has been initially executed?
It used to be after a reboot of a server you could type the word 'setup' at the very first login prompt after boot up, but I don't see that option any more.
I tried typing 'setup' at the first login prompt, but its just shows a bad login, rather than running the setup script.
The 'write erase' command is also disabled in 2.2, so I can't use that to start again and force a the setup script to run.
Looks like once you have run setup once, you're stuck with that config? If you want to switch a unit to be a HA secondary, do you have to wipe the box and start again...?
I've checked the user, admin, quick start and command reference guides, but there is no reference about how to run  the setup script a second time.
Nigel.
3 REPLIES 3
Beginner
Did you ever get an answer on
Did you ever get an answer on this?  I am in the exact same position with my Prime installation. I want to make the second appliance an HA server now but don't want to have to go through the OVA provisioning 5+ hours....
Beginner
Hopefully this helps, because
Hopefully this helps, because there is literally no documentation out there for running this command.  Here is how to run the script...
SSH to the prime node
shell
sudo /opt/CSCOlumos/bin/setup.sh
or
cd /opt/CSCOlumos/bin/
sudo ./hamode.sh primary
or
sudo ./hamode.sh secondary
Re: Hopefully this helps, because
Thanks so much DanLeeRankin. The usual method was not working in 3.3/3.4 and your shell command
to restart setup script works perfect on 3.4.
Content for Community-Ad
August's Community Spotlight Awards
