05-26-2010 04:05 AM - edited 07-03-2021 06:49 PM
HI
I am try to setting wpa2+aes+psk with mac-filter (radius) on WLC 4402 (6.0.182), with Lap - 1142
on security , set L2 security wpa+wpa2 and check MAC filtering
uncheck WPA
check WPA2, AES, unckeck TKIP
Auth key mgmt PSK
psk fromat ASCII
L3 none
uncheck web policy
AAA servers
select radius server enable accounting server
It's work fine , when I using WEP with mac-filter(radius)
but when I select WPA2 it's fail and no log both on WLC and radius server
Is this limitation or bug....
Thanks in advance for your help
Solved! Go to Solution.
05-26-2010 05:19 AM
That sounds like it should work. Maybe your client doesnt like wpa2/aes or the PSK doesnt match. I'd try to associate with that same config, but without the mac filtering enabled to try to narrow down the problem.
-John
05-26-2010 05:19 AM
-John
05-30-2010 06:46 PM
Ha.... It's Bug CSCta53985
test on 6.0.196 work fine
Thank alot
