ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Identifying unpositioned APs on Prime (3.7) maps
Hello
Is there a simple way to identify APs which have been added to a map, but have not been positioned yet? Only way I found is to check every single map if there is the blue flag symbol, which indicates unpositioned APs for the map (in case there are any).  As we have hundreds of maps, doing it this way is very time-consuming.
Thanks a lot
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: Identifying unpositioned APs on Prime (3.7) maps
You have to go through each map and look. There is no way to see if the ap is placed and or placed properly.
-Scott
1 REPLY 1
Highlighted
Hall of Fame Master
-Scott
Content for Community-Ad
