Community Helping Community
464
If a WLC fails?
I've been asked to find out what happens if a WLC fails?
Do clients stay connected but can't connect new clients? Does everyone get kicked off?
Does the same happen with the Virtual WLC as does with a hardware box? Should I really have two WLC's ?
Everyone's tags (2)
4 REPLIES 4
Hall of Fame Community Legend
Re: If a WLC fails?
Depends.  If you don't have FlexConnect AND you don't have any redundant WLC, then clients get booted off.
Let say you don't have a redundant WLC but you have FlexConnect.  If the WLC fails then the OLD client will stay connected.  Unless you have a local authentication server at each site, then NO NEW clients will be able to authenticate.   Another thing, when the WLC fails, the AP must NOT be reloaded.  If it does, then no clients, old and new, will be able to join the wireless network
Let's say you don't have FlexConnect.  When the primary WLC fails, the AP will join the secondary WLC.  During the "move" from Primary to Seconday, the clients will loose connection.
Re: If a WLC fails?
Thanks.
Highlighted
Hall of Fame Master
Re: If a WLC fails?
And if you are using FlexConnect and 802.1x without redundant radius, the client will eventually fail to join.... and stuff.
-Scott
Re: If a WLC fails?
Content for Community-Ad
August's Community Spotlight Awards
