09-21-2018 02:42 PM - edited 07-05-2021 09:12 AM
I have been getting lot of complaints from the C-level about the speed of the wireless network. Tests on the wired network yield 700+ Mbps but the wireless strains to reach 24 Mbps.
I do not expect the wireless network to match the wired network in speed or reliability but the above does seem a bit of an excessive difference. Is there any good documentation on improving wireless performance?
Controller: 5508 (two configured as active-passive)
Access Points: AIR-CAP3702E (17 local; 29 total)
All APs are in Flex-Connect mode.
Solved! Go to Solution.
10-15-2018 11:48 PM
09-21-2018 04:04 PM
You really need to provide more information, for example what band are the clients connecting? What channel? To what standard? Are the effected clients all connected to one AP?
It's never a bad idea to perform a spectrum analysis, as it gives an insight to the environment, it may be there is a lot of co channel interference or congestion, or some external interference.
Martin
09-21-2018 05:13 PM
10-05-2018 04:58 PM
I am not sure if this is what you are asking for but show sysinfo lists
Product Version.................................. 8.0.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
I tested doing a file transfers with ftp and sftp. That is what the bigshots are complaining about. I also use the speed test at http://www.dslreports.com/speedtest to test connections to the outside world.
I do not know what Wireless NIC the wheels are using. All I really know is they are using MACs. I tested using a Dell Latitude E6540 which probably uses the built in wireless. The latop is running CentOS 6.10. The kernel version is 2.6.32. The driver module is iwlwifi which covers quite a few Intel chipsets.
I tested both 2.4 and 5 Ghz. Both seemed to transfer files at about the same speed.
10-06-2018 04:47 AM
10-08-2018 12:41 PM
I used a Fluke One Touch AT to check the signal strength in the offices and conference rooms. The SSID they connect to varies from -46 dBm to -52 dBm. The access point I am using to test registers about -45 dBm
The Air Quality Reports averages 99% to 100% for 802.11a/n/ac and 95% to 99% for 802.11b/g/n.
According to the 5508, the laptop I am using for testing is connected via 802.11an which, if I understand the nomenclature correctly, is 5 GHz.
Everything looks pretty good to me.
Using sftp, I just transferred a 1.07 G file in 3m 27s which translates to 5.2 MB/s or about 41 Mb/s.
My configuration is attached.
10-09-2018 12:35 AM
I think you are only checking the signal strength on the mentioned rooms and the signal strenght could be one factor to slow teh wifi, however it seems is not your issue.
Can you provide more information about your Wi-Fi configuration as :
- Are you using Band Steering on your SSID?
- Are you using separate SSID for 2.4 Ghz and 5 Ghz? If not, I highly recommend to do it due one 2.4 Device could slow your Wi-Fi significally.
- Are you using RF profiles? Maybe are you using teh defailt one? If yes which is the beacon that you are using?
I think (wihtout the information requested) your porblem could be located on the beacons that you are using. This could cause that one client will be connected to one AP that is not the better one on that location (maybe the roaming didn't complete correclty).
10-09-2018 02:27 PM - edited 10-09-2018 02:28 PM
I had to look up Band Steering/Select and I am not using it. I turned it up on the test SSID I am using and it connects at 5.745 GHz but only transfers at about 35 to 40 Mb/s over sftp. I know sftp is slower than ftp or nfs but sftp is what the big shots want to use. I can get sustained speeds of 700 to 800 Mb/s from sftp over a wired conenction.
I didn't know that I could even force a SSID on the 5508 to use 2.5 versus 5 GHz. I can certainly setup separate SSIDs for most of the users. At least one SSID will have to support 2.5 because some devices on the network just do not support 5 GHz.
As near as I can tell, I have no RF profiles defined.
That could be. Could FlexConnect have anything to do with it? I use it because there are APs at remote offices that are managed by the 5508.
10-11-2018 05:34 AM - edited 10-11-2018 05:35 AM
What encryption are you using on the SSID?
> 802.11n and AC speeds are only possible if WMM is enabled (not disabled) and you use WPA2 with AES (or no encryption at all). WPA, WEP and/or TKIP all don't support high speeds.
Can you check the MAC address of a client and then issue the following command on the wlc:
show client detail herethemacaddress
Please post the full output of that command (you can remove the username, IP addresses and ssid name if you like).
10-11-2018 12:44 PM
Here is the output. Seems a little odd it doesn't support rates over 54 Mb/s. I checked some other machines -- Windows and Macs -- and they all seem to have the same limit. Guess I need to do some more studying.
Client MAC Address............................... 80:00:0b:8a:d2:c5 Client Username ................................. N/A AP MAC Address................................... 58:97:bd:3e:2d:b0 AP Name.......................................... Co5897bd26e720.lereta.net AP radio slot Id................................. 1 Client State..................................... Associated Client User Group................................ Client NAC OOB State............................. Access Wireless LAN Id.................................. 3 Wireless LAN Network Name (SSID)................. LeretaNW Wireless LAN Profile Name........................ LeretaNetWork Hotspot (802.11u)................................ Not Supported BSSID............................................ 58:97:bd:3e:2d:be Connected For ................................... 209 secs Channel.......................................... 60 IP Address....................................... 10.212.56.12 Gateway Address.................................. 10.212.56.1 Netmask.......................................... 255.255.255.0 Association Id................................... 1 Authentication Algorithm......................... Open System Reason Code...................................... 1 Status Code...................................... 0 Session Timeout.................................. 0 Client CCX version............................... No CCX support QoS Level........................................ Silver Avg data Rate.................................... 0 Burst data Rate.................................. 0 Avg Real time data Rate.......................... 0 Burst Real Time data Rate........................ 0 802.1P Priority Tag.............................. disabled CTS Security Group Tag........................... Not Applicable KTS CAC Capability............................... No WMM Support...................................... Enabled APSD ACs....................................... BK BE VI VO Power Save....................................... OFF Current Rate..................................... m10 Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0, ............................................. 48.0,54.0 Mobility State................................... Local Mobility Move Count.............................. 0 Security Policy Completed........................ Yes Policy Manager State............................. RUN Policy Manager Rule Created...................... Yes Audit Session ID................................. 0ad4035b000252f05bbf939a AAA Role Type.................................... none Local Policy Applied............................. none IPv4 ACL Name.................................... none FlexConnect ACL Applied Status................... Unavailable IPv4 ACL Applied Status.......................... Unavailable IPv6 ACL Name.................................... none IPv6 ACL Applied Status.......................... Unavailable Layer2 ACL Name.................................. none Layer2 ACL Applied Status........................ Unavailable Client Type...................................... SimpleIP mDNS Status...................................... Disabled mDNS Profile Name................................ none No. of mDNS Services Advertised.................. 0 Policy Type...................................... WPA2 Authentication Key Management.................... PSK Encryption Cipher................................ CCMP (AES) Protected Management Frame ...................... No Management Frame Protection...................... No EAP Type......................................... Unknown FlexConnect Data Switching....................... Local FlexConnect Dhcp Status.......................... Local FlexConnect Vlan Based Central Switching......... No FlexConnect Authentication....................... Central FlexConnect Central Association.................. No Quarantine VLAN.................................. 0 Access VLAN...................................... 56 Local Bridging VLAN.............................. 56 Client Capabilities: CF Pollable................................ Not implemented CF Poll Request............................ Not implemented Short Preamble............................. Not implemented PBCC....................................... Not implemented Channel Agility............................ Not implemented Listen Interval............................ 10 Fast BSS Transition........................ Not implemented Client Wifi Direct Capabilities: WFD capable................................ No Manged WFD capable......................... No Cross Connection Capable................... No Support Concurrent Operation............... No Fast BSS Transition Details: Client Statistics: Number of Bytes Received................... 13937 Number of Bytes Sent....................... 35216 Total Number of Bytes Sent................. 35216 Total Number of Bytes Recv................. 13937 Number of Bytes Sent (last 90s)............ 1660 Number of Bytes Recv (last 90s)............ 1466 Number of Packets Received................. 135 Number of Packets Sent..................... 340 Number of Interim-Update Sent.............. 0 Number of EAP Id Request Msg Timeouts...... 0 Number of EAP Id Request Msg Failures...... 0 Number of EAP Request Msg Timeouts......... 0 Number of EAP Request Msg Failures......... 0 Number of EAP Key Msg Timeouts............. 0 Number of EAP Key Msg Failures............. 0 Number of Data Retries..................... 215 Number of RTS Retries...................... 0 Number of Duplicate Received Packets....... 2 Number of Decrypt Failed Packets........... 0 Number of Mic Failured Packets............. 0 Number of Mic Missing Packets.............. 0 Number of RA Packets Dropped............... 0 Number of Policy Errors.................... 0 Radio Signal Strength Indicator............ -78 dBm Signal to Noise Ratio...................... 19 dB Client Rate Limiting Statistics: Number of Data Packets Received............ 0 Number of Data Rx Packets Dropped.......... 0 Number of Data Bytes Received.............. 0 Number of Data Rx Bytes Dropped............ 0 Number of Realtime Packets Received........ 0 Number of Realtime Rx Packets Dropped...... 0 Number of Realtime Bytes Received.......... 0 Number of Realtime Rx Bytes Dropped........ 0 Number of Data Packets Sent................ 0 Number of Data Tx Packets Dropped.......... 0 Number of Data Bytes Sent.................. 0 Number of Data Tx Bytes Dropped............ 0 Number of Realtime Packets Sent............ 0 Number of Realtime Tx Packets Dropped...... 0 Number of Realtime Bytes Sent.............. 0 Number of Realtime Tx Bytes Dropped........ 0 Nearby AP Statistics: Co188b9dc09778.le(slot 0) antenna0: 73 secs ago.................... -76 dBm antenna1: 73 secs ago.................... -77 dBm Co188b9dc09778.le(slot 1) antenna0: 72 secs ago.................... -82 dBm antenna1: 72 secs ago.................... -80 dBm Co188b9dc09b54.le(slot 0) antenna0: 132 secs ago................... -90 dBm Co5897bd26e720.le(slot 0) antenna0: 72 secs ago.................... -75 dBm antenna1: 72 secs ago.................... -76 dBm Co5897bd26e720.le(slot 1) antenna0: 70 secs ago.................... -86 dBm antenna1: 70 secs ago.................... -83 dBm DNS Server details: DNS server IP ............................. 10.212.3.26 DNS server IP ............................. 10.212.3.27 Assisted Roaming Prediction List details: Client Dhcp Required: False Allowed (URL)IP Addresses ------------------------- AVC Profile Name: ............................... none
10-12-2018 02:05 AM
10-12-2018 08:33 AM
@patoberli wrote:
Based on this output you seem to have ok speed:
But the signal is quite weak:
I noticed the weak signal so I restricted the test SSID I set up to only the AP closest to me. It looks a little better now though the fact it was necessary indicates an issue with clients not always connecting to the AP with the best signal.
Current Rate..................................... m14 Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0, ............................................. 48.0,54.0 Radio Signal Strength Indicator............ -51 dBm Signal to Noise Ratio...................... 45 dB
Encryption looks fine, so does WMM.
Just to be sure, can you check on the WLC under Wireless -> 802.11a/n/ac -> High Throughput if everything is enabled there?
I checked and both 11n and 11ac modes are enabled.
BTW, what does a current rate like m10 or m14 mean?
10-12-2018 10:42 AM
Have a look here for an explanation of the rates:
It's a tad weird, that it doesn't show the amount of streams on your output, but might be a software version thing.
In any case, you seem to be connected at a fairly good speed, how do you measure the performance?
I suggest to use a wired client running iperf in server mode and a wireless client running it in client mode.
10-12-2018 12:03 PM
Thank you for the reference. It is very helpful
I was using SFTP to transfer files because that and FTP is what the developers are using. The transfer rates I get from iperf are consistent with the sftp speeds. EG:
------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 85.3 KByte (default) ------------------------------------------------------------ [ 4] local 198.204.114.92 port 5001 connected with 10.212.56.131 port 45106 [ ID] Interval Transfer Bandwidth [ 4] 0.0-10.2 sec 35.4 MBytes 29.1 Mbits/sec ------------------------------------------------------------ Client connecting to 10.212.56.131, TCP port 5001 TCP window size: 81.2 KByte (default) ------------------------------------------------------------ [ 4] local 198.204.114.92 port 59024 connected with 10.212.56.131 port 5001 [ 4] 0.0-10.1 sec 51.6 MBytes 43.1 Mbits/sec
I have to come in tomorrow evening to run some patches and I will bring in my personal laptop which has better diagnostic tools.
10-13-2018 01:02 AM
