Community Helping Community
244
Highlighted
Beginner
ios 7.0.x SSID problems
We're having a problem with ios devices for some time now. When connected to an SSID on the iPad I can't switch  to another SSID. I have to use the button "forget this network" to connect with another SSID. Are there others that are facing this problem? It looks like it's not even trying to connect to the WLC.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: ios 7.0.x SSID problems
You need to make sure you have Fast SSID Change enabled on the WLC. This can be found in the WLC GUI under The controller tab.
-Scott
3 REPLIES 3
Hall of Fame Master
-Scott
Beginner
Thank you Scott, that did the trick
Hall of Fame Master
Good to know... Glad that worked for you!
-Scott
Content for Community-Ad
August's Community Spotlight Awards
