11-12-2015 11:44 AM - edited 07-05-2021 04:13 AM
hello
i confiure new SSID authentecetd using Microsoft Active Directory , i used in my profile PEAP , its works fine with SAMSOUNG phones , but not with Apple Devices.
please any suggesting.
i dont not use any certificate until now , is it necessary ?
Ali
Solved! Go to Solution.
11-17-2015 02:48 PM
Are you using a controller based wireless network or autonomous access point and what code versions are being used?
John
11-16-2015 04:17 PM
What error do you get with the Apple Devices?
John
11-17-2015 12:17 PM
hello
the error " unable to joint network"
11-17-2015 02:48 PM
John
11-18-2015 12:16 PM
i used controller based wireless , code 7.6
11-18-2015 04:18 PM
Make sure Fast SSID change is enabled on the wireless controller. Check that the Apple device is running the latest software. Upgrade the sotware on the wireless controller since 7.6 is deferred code.
John
