Cisco Community Designated VIP Class of 2020
179
Beginner
IPv6 for wifi Clients
I would like to enable IPv6 for an office WLAN.
At present we have a dual stack network on a wired FLAT LAN (the WLAN shares the same Subnet/VLAN). Developers use IPv6 on the LAN mostly for testing, but at present must patch into a wired Ethernet port to use it. It would be handy for them to utilize the IPv6 network while on the WLAN.
The wireless is a single AP running the MEC software and acting as the office AP /Controller
What configuration changes must I make to allow IPv6 on the WLAN? Should it work by default?
Is there a way to enable it in the GUI? Or, must I enable in CLI?
Thank you, Pat
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
Re: IPv6 for wifi Clients
If it is a Mobility Express AP, pls follow below guide
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/ipv6.html
Rasika
*** Pls rate all useful responses ***
1 REPLY 1
Highlighted
VIP Mentor
Rasika
Content for Community-Ad
August's Community Spotlight Awards
