ISE and WLC(5508)-Guidance?
gciarrocchi
Evening,
Here's a fun "where's Waldo" for anyone interested
Let's say I have a couple hundred AP's connected to 4x 5508 WLC's.
2 WLC's are for Buildings A,B,C,D.
2 other WLC's are for building E,F,G,H
All 4 WLC's point to the same ISE 2.3.
3 WLAN's exist across all 4 WLC's
SSID_old used 802 with Web Auth (Impulse Safeconnect device)
SSID_new and SSID_new_guest use Radius/PEAP and allow authentication via AD credentials and Captive Portal for the guest to login via AD creds OR guest use.
All WLANS work authenticating on buildings A,B,C,D.
Buildings E,F,G,H..... that's another story.
SSID_New prompts for your AD credentials, takes them, authenticates user fine. When you go to brownse, you get redirected to the Impulse Safeconnect, which is where the RUB is.
Where would I find this redirection after successfull PEAP auth?
Come to think of it, is your old portal being redirected from the FW or router?  Once the WLC places the traffic in the network, it’s not redirecting anything. So unless you have an appliance inline that hijacks the session, that could be it, but you should look at the existing design to see where the other configurations are being set. I’m assuming you are using the same subnet?
-Scott
Scott Fella
It’s your allowed protocols and policies that is allowing that. Look at your radius logs and see which policy a device is hitting.
-Scott
-Scott
Thanks Scott,
Inline appliance listening on the same subnets as the AP groups.
Reconfigured and running now.
