ISE - Cannot cancel backup process
ruud.manders
The backup process has stalled; Moving Backup file to the repository
There was a problem with the backup server during this process.
Now it doesn't proceed with the move.
Is there a way to cancel this operation?
Using the Cancel link is not allowed: Backup file is currently being transferred to the repository. Cancel is not permitted
Anyone who knows what to do?
Thanks in advance.
Ruud
12 Replies 12
csco11552159
Level 5
Level 5
how do you solve it ?
i have same problem.
__Beth__
For anyone else that may have this issue, the only way I know how to resolve it is to reload ISE.
whats your version and patch ? what protocol did you use for backup ?
I have seen something similar with scp with one of my customer.
-hope this helps-
Currently, 1.4 Patch 10.  We use FTP.  I also had it happen with 2.1, which was a miserable experience.  So bad, we rolled back.
I have found elsewhere in supportforums that performing a manual CLI backup will unhang a backup. I have not tried it though ... yet
https://supportforums.cisco.com/t5/security-and-network-management/ise-backup-process-hangs-in-cancelation/td-p/2713825
I have had problems with the op backup hanging.  Also we have frequent failures of the config backup so we are hesitant to confound problems further by scheduling a ops backup.
Ver 2.1 patch 3
I had the same problem with my deployment just now (ISE 2.1, patch 3). Can confirm that starting a backup from CLI (backup name repository respositoryname ise-config encryption-key encryptionkey) has put it back to normal.
The CLI backup trick did not cancel the GUI backup. We are 2.1 Patch 3
We had to reload.
The message below is my CLI backup being cancelled because the GUI one was in progress.
ise/admin# backup GSS_ISE_CLI repo ********* ise-config encry plain *************
% Warning: Waiting up to 1200 seconds for APP_BACKUP to finish...
% Warning: Cannot continue backup as APP_BACKUP is running
% The backup is cancelled
ise/admin#
CSCvc28417
ISE back-up fails intermittently from CLI and GUI.
Had the same issue on ISE 2.3 patch 1. Resolved starting backup for cfg and oper data from the CLI.
Rick.
2.3 patch 1 for us startign from the CLI did the trick as well
rhuel.phils
I had this problem too. Can anyone confirm if Reload ISE is the only way to resolve this?
Thanks!
Yes this is a bug in version 2.3 Patch 1. You can either reload or issue "Application stop ise"
This has been confirmed as fixed in Patch 2, which is the reason i had ours upgraded
we are on v2.3 patch 3
issuing "application stop ise" results in the following:
Waiting up to 20 seconds for lock: APP_BACKUP APP_BACKUP to complete
Database is still locked by lock: APP_BACKUP APP_BACKUP. Aborting. Please try it later
% Error: Another ISE DB process (APP_BACKUP APP_BACKUP) is in progress, cannot perform Application Stop at this time
issuing "backup name repository respositoryname ise-config encryption-key encryptionkey" results in the following:
at this point, planning to reload. for future reference though, any advice would be greatly appreciated. thanks!
