Community Live- Understanding How Multicast Works with Cisco
277
Beginner
ISE DHCP
Hello, I have Cisco 5508 WLC, and also i have Cisco ISE, When i created the radius configuration between the WLC and ISE after the authentication using mobile phone the i can't get ip from dhcp but when i setup the authentication from the WLC to use WAP the dhcp working without any issues
Everyone's tags (2)
5 REPLIES 5
Collaborator
Re: ISE DHCP
What authentication are you using with ISE?
John
**Please rate posts you find helpful**
Beginner
Re: ISE DHCP
Local Users
Collaborator
Re: ISE DHCP
Are you using wpa/wpa2 with peap? Post screenshot  of the wireless and ISE config with sensitive info removed
John
Highlighted
Beginner
Re: ISE DHCP
Please give me commands
VIP Advisor
Re: ISE DHCP
I suggest to read this blog, have all the information what you looking to setup.
you need to integrate WLC with ISE.
https://mrncciew.com/2014/05/11/wlc-access-via-radius-ise/
BB
*** Rate All Helpful Responses ***
Content for Community-Ad
August's Community Spotlight Awards
