07-24-2014 03:49 AM - edited 07-05-2021 01:16 AM
Dear all, I need to manage some 1231g with 5508 Wlc version 7.4.xx , I know that I have to use the version 7.0.xx: how can I download it?
07-24-2014 06:41 AM
There is only one and that is to downgrade 500 wlc software to 7.0.250.0 then only you can connect 1231AP to this wlc.
If you ahve a smartnet contarct then you can downloa dfrom here:
http://software.cisco.com/download/release.html?mdfid=282600534&flowid=7012&softwareid=280926587&release=7.6.120.0&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Dont forget to arte helpful posts
09-29-2014 05:10 AM
you can download 7.0.x code from below link.
10-06-2014 02:34 AM
Thanks guys!
and if need I to join 1231g with ct5508-HA? can I modificate the HA in any way to do it?
