02-21-2012 12:13 PM - edited 07-03-2021 09:37 PM
Hello guys
i have a wlc 5508 , and i want to enable LAG, but i want to connect 4 ports in one module and the rest 4 ports in another module,
for example
Gigabitethernet1/45 - 1/48
Gigabitethernet3/10 - 3/13
both modules in the same core switch (6506) obviously using the same port channel , so at the end i would have redundancy between modules for when a module fails.
or all the 8 ports needs to connect to the same module, ?
i mean 1/40 - 1/47 for example...
Thnks!!!!
Solved! Go to Solution.
02-21-2012 12:16 PM
Luis,
you can split the ports across multiple modules in your switches. THe only thing you can't do is spli the lag across multiple switches, unless VSS.
Steve
02-21-2012 12:16 PM
If you are running VSS between the two cores you would be able to split the port channel.
02-21-2012 12:16 PM
Luis,
Steve
02-21-2012 12:31 PM
Luis,
You can connect the 8 ports to the two modules if they are stacked modules, which means they under the same management IP. If you want to use two separate switches, then you would must run VSS.
02-21-2012 02:29 PM
Thnk you guys,
i'll served a lot your help
greetings !!!
