Community Live- Understanding How Multicast Works with Cisco
1529
Beginner
lap1262n lap to autonomous
                   Hello Colleagues
Please there is any way to change the OS from LAP to Autonomous for  lap1262n
2 ACCEPTED SOLUTIONS
Hall of Fame Master
Change your subnet mask on your PC to 255.255.255.0 and no need for a default gateway.  Disable any firewall on your machine and then follow the previous instructions.  You don't need to change the ip address on the AP and now you willo need to erase and reboot.  So when you are in the CLI of the AP, issue a write erase and then reboot without saving.  When the ap comes back, make sure there is no static address set.  Then follow the proceedures above.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Participant
Hello Driss,
This topic is a little confusing, I did the conversion many time ago and for not confusing you I recommed you to watch this youtube videos:
http://www.youtube.com/watch?v=wWDrFjwVNb0
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
If it is useful please rate.
Best regards.
18 REPLIES 18
Hall of Fame Master
Re: lap1262n lap to autonomous
You can... You just need to be able to download the IOS image and then follow these directions.
https://supportforums.cisco.com/docs/DOC-14960
-Scott
Beginner
Hello Scott
Thank s a lot for your respond , actualy there is 2 software , did i need to install both of them
1 Autonomous AP IOS Software
2 IOS Software
http://www.cisco.com/cisco/software/type.html?mdfid=283307705&flowid=16361
Hall of Fame Community Legend
Use Autonomous AP IOS.  Please DO NOT use 15.2(2) if you are going to run 802.1Q.
Beginner
Hello
Thank you for your respond
at the debug option
APacf2.c50a.674c#debug lwapp ?
  client               LWAPP Client Debug Options
  iapp-data-echo  LWAPP IAPP data plane echo
APacf2.c50a.674c#debug capwap ?
  client  CAPWAP Client Debug Options
  mcast   CAPWAP MCAST Debug Options
  mfp     CAPWAP MFP Debug Options
After : debug lwapp and debug capwap there is no consol cli command after that  how can i go to the config t
Hall of Fame Master
It's a hidden command.... You just need to type it in. Use the archive download command and tftp the IOS image.
-Scott
Beginner
Hello Scott
Thank you for the helpfull command  , but i'm geeting confisued
1 i assigned static ip for both PC and the AP but i cannot reache it to upload the file
2 i plug the POE switch on my  home LAB with DHCP enable i cannot reach the access point
Highlighted
Hall of Fame Master
Well first off just remember that the AP will default using 10.0.0.1 /24 so you should set your PC for 10.0.0.2 /24. Also make sure you can ping the AP so do a continuos ping to the AP and disable your firewall. I use 3CDeamon for my tftp server but tftpd32 also works good.
-Scott
Beginner
i flowed you instruction but the same host unreachable
1 i'm connecting the power to AP
2 back to bak cable from AP 10.0.0.1  to the PC 10.0.0.2/24
Hall of Fame Master
Can you ping?  Connect the AP and the PC to a switch on the same vlan... doens't matter what vlan as long as they are on the same.  Might be the cable you are using also...
Scott
-Scott
Beginner
i have asign ip address to BVI
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.36.227.242   YES manual up                    up
GigabitEthernet0           unassigned      YES TFTP   up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
it's pinging to the PC
APacf2.c50a.674c#ping 10.36.227.60
Sending 5, 100-byte ICMP Echos to 10.36.227.60, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/80/381 ms
APacf2.c50a.674c#
also from the PC
it's pinging as well the IOS can upgrade via the BVI int
why is not pinging when i'm assining to int gi0 the same ip to the BVI
Beginner
Hello Driss,
Just one question, you press the button "mode" on startup by 25 seconds?
You will receive the following example in CLI:
button is pressed, wait for button to be released...
button pressed for 25 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image...
After you can get access to do the process.
Regards.
Beginner
hello Rafael
i did what you advicce
i did set ip addess to 10.0.0.1
what the procedure to type image recovery
what the procedure to download tar image
copy from AP
show_ether -- show ethernet port statistics
    show_pci -- show pci setting
     sscdump -- sscdump
      sscoff -- turn off ssc
switch status -- report push button switch status
         tar -- extract or listing a tar file
   tftp_init -- Initialize tftp file system
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
ap: set ip address
ap:
ap:
ap:
ap:
thank you
Beginner
Hello Driss,
Look steps:
Step 1 - The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 - Make sure that the PC contains the access point image file (such as ap3g1-k9w7-tar.124-25d.JA2.tar for a 1260 series access point) in the TFTP server folder and that the TFTP server is activated (set the timeout value on the TFTP server to 30 seconds).
Step 3 - On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall or others.
b. If you are using Windows -> Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 4 - Rename the access point image file in the TFTP server folder to "c1260-k9w7-tar.default" for a 1260 series access point.
Step 5 - Connect the PC to the access point and disconnect power from the access point.
Step 6 - Press and hold MODE while you reconnect power to the access point.
Step 7 - Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8 - Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 - After the access point reboots and you completed work.
or
If you have one Controller working, you can downgrade by WLC also, check:
(Cisco Controller) >config ap tftp-downgrade your_ip ap3g1-k9w7-tar.124-25d.JA2.tar ap_name
Regards.
Beginner
Hello Rafael
Thank you for your reply i have cheked all you sugest but i cannot reach the the wifi  my pc has 10.0.0.2 ip with subnet 255.0.0.0
BVI1                       unassigned      YES DHCP   up                    up
GigabitEthernet0           10.0.0.1        YES manual up                    up
APacf2.c50a.674c(config)#
Content for Community-Ad
August's Community Spotlight Awards
