113
Beginner
Laptops can't connect to SSID enabled with security
I have a very weird issue with a specific office. My users are not able to connect to my corporate SSID.
Wireshark shows that there is no communication between AP and laptop with security turned on
Laptop works fine connecting to my guest account with security enabled
Remove security - set SSID to open - works fine no problem
I'm not having issue any where else on my network.
I've been working with Cisco for over a week - no progress ... any ideas
Thanks in advanced
3 REPLIES 3
Highlighted
VIP Advisor
Re: Laptops can't connect to SSID enabled with security
 run debug client while trying to connect and share the output. It seems to me a authentication problem. Which authentication method do you have in you Corporate SSID?
-If I helped you somehow, please, rate it as useful.-
Beginner
That's the issue, when  I debug a client trying to connect to my WLAN SSID - there is no traffic with security enabled.
If I remove security I am able to see traffic between laptop and wireless network.
Just want to add that other AP's throughout our corporate network work just fine.
Seems to be office specific issue but cannot get any evidence from Cisco.
VIP Advocate
What kind of client?
What wi-fi adapter and which driver version?
Which software release is installed on your WLC/AP?
What security options do you test? I suggest to only use WPA2 with AES and PSK for testing.
This sounds like a driver problem.
Content for Community-Ad
August's Community Spotlight Awards
