Community Live- Understanding How Multicast Works with Cisco
370
Beginner
Load Profile Failed
Last week one of our 9 APs (1140) wasnt able to accept connections. I rebooted the AP and again all worked. But on my debug I found this (and again today) (attached image)
7 REPLIES 7
Hall of Fame Master
Re: Load Profile Failed
That is a threshold setting that can be adjusted. Doesn't affect client connectivity. If your on v7.4 with 1142's then you can be running into a known bug.
-Scott
Highlighted
Beginner
This is my version
BTW Do you suggest upgrade firmware?
Hall of Fame Master
Well you can, but I would just go with the latest version on the 7.0 train which is v7.0.240.0. Make sure that client load balancing is disabled also.
-Scott
Beginner
Yes it is :-)
TYou
Hall of Fame Master
Then keep track to see if its a given AP or not. Can be an issue with an AP, especially if a reboot of the AP fixes it. You can try swapping APs around to see if the issue follows the AP or not.
-Scott
Hall of Fame Master
Here is the bug ID just in case your using v7.4
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud97983
-Scott
Hall of Fame Master
You can run this command on a given ap to see the utilization
show ap auto-rf {802.11a | 802.11b} Cisco_AP
-Scott
Content for Community-Ad
August's Community Spotlight Awards
