LOCAL-LEAP SSID NEVER SHOWS UP
daswann
Using the WLC 2500, a 3750 and an AP3702i. Broadcast SSID is checked but never shows up in the air?
Status=Enable
Profile = Local-LEAP
SSID = Local-LEAP
Interface-Group =VLAN2
NAS-ID=NONE
L2 Security=WAP+WPA2
AES
802.1x Key management is checked
AAA Servers
Local EAP Authentication enabled checked
EAP Profile Name = Local-LEAP
PEAP authentication works fine.
Thanks in advance
DASTAS
I created a new AP group when I started testing with PEAP. However I think you may have found it. I don't see the LEAP profile in there. Just added it. The AP rebooted and I now see the SSID.
Thanks Flavio good eye!
Dale
6 Replies 6
If the WLAN is enabled and broadcast SSID is enabled then there´s no alternative, it has to show up.
The first thing I need to ask is if the AP is fully joined on the WLC? How many AP does the WLC has? It happen with all APs?
 Can you check that?
-If I helped you somehow, please, rate it as useful.-
Flavio,
Thank you for your response. This is in my test environment with one AP 3702i,and one WLC 2504. My other SSID's are broadcasting ie. PEAP, PSK, Open etc. I have worked with wireless 802.1x authentication for many years for Aruba, so I believe I have everything configured correctly. The version of code on the WLC is 8.3.112.0.
Alright, for security just avoid using tkip.
 As you have only one AP probably you are using default group, right?
 If you are using AP group you need to add the SSID on it.
 What about network 892.11a and b. They are enabled under WIRELESS tab?
Take a look on AP radius as well.
It is all I can recall for now.
Dale
Flavio
You found it! I created a new AP group for this but did not add the LEAP SSID to it.
Thank You!
Alright. Please rate it and change to solved please.
