07-16-2019 08:09 AM - edited 07-05-2021 10:42 AM
Is this because the difference about WPA2-PSK Security and Mac Filtering Security ? it can say that its the weakness of Mac Filtering Security, this is below the scenario test
07-16-2019 09:41 AM
The client dictates which AP it will connect to. Sometimes it's hard to force the client over to a different AP when it can still see the first AP.
07-16-2019 07:36 PM
yeah but with this mac filtering security make signal indicator looks weak then effect to data rate or connection, but if I use WPA2-PSK it could good and quick transition to the AP that near with the client, it can say automatically connect in,
the real question how do I make SSID with local mac filtering could do fast transition in different AP that near with him ?
Thank you for your response
