Does anyone know a set of CLI commands that I can use to determine the IP address for the Non-Root bridge (Cisco 1310 running 12.4(25d)JA1) that a given MAC address is behind. For this case, the root-bridge is trunking VLANs across to several non-root bridges. On a wired network, tracing out the L2 path to the client switch port is farely simple to script in linux. When Cisco bridged wireless is in the mix for trunking where physical medium is not possible, not so simple. I appreciate any pointers. Thanks.
