Location Manager does not launch
john.sobrinho
Hi all..
Running WLSE 2.7.1 and have repeatedly uninstall / reinstall the java client, to no avail.
The Location Manager is able to detect that I am runing java but can not detect the version.
John
smalkeric
Level 6
Level 6
Check to see if multiple plugin vesions are installed on the same PC. You can go to Windows Control Panel > add/remove programs and remove all the pluggins. Then do a fresh installation of the required plug in.
