Log in WLC 5508
Hello.
Someone knows what does it mean this log in the wlc 5508 with 7.5 IOS version:
*apfMsConnTask_5: Oct 25 12:07:04.880: #APF-4-RCV_ACTION_FRM_WITH_CODE: apf_80211k.c:643 Received Action frame with code 4 from mobile station 4C:8D:79:CF:9B:53
Because some IPODS and IPADS have problems to connect in the wireless network.
Thanks a lot!
Lisa Latour
Level 6
Level 6
hello - I found your post in a non-visible-non topic community -- I have moved it into the Wireless Area - perhaps this should help garner an answer for you
Hope you have got a resolution for this.(since it is 1 yr old post).
7.6.130.0 is the recommended code if you are still with 7.5.x
Rasika
abwahid
Level 4
Level 4
Error Message
%APF-4-RCV_ACTION_FRM_WITH_CODE: Received Action frame with code [dec] from mobile station [chars]
Explanation
Received a Action frame with
code from a mobile station.
Recommended Action
No action is required.
Error Message
%APF-3-RCV_ASS_RREQ: We’ve received an Association request - must have been an error.
Explanation
Recommended Action
Copy the message exactly as it appears on the console or in the system log.
Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac With some messages, these tools and utilities will supply clarifying information.
