Looking for info on "test wlan dot1x radius" command
Is there a way to perform RADIUS connectivity and optionally basic auth testing, without a client?
I see the "test wlan dot1x radius" command in the CLI which looks promising, but I can't find any info on it.
The "test ..." commands aren't in the Command Reference (?!)
Can anyone provide any info on how the above command works (if at all)
Thanks in advance
Everyone's tags (4)
2 REPLIES 2
Highlighted
Hall of Fame Master
Re: Looking for info on "test wlan dot1x radius" command
For testing radius, I use NTRadPing. Might be a better option for you.
http://www.novell.com/coolsolutions/tools/14377.html
-Scott
Highlighted
Ntrad is the way to go. It acts like a client and easy to use .. Fan of the program !
Content for Community-Ad
August's Community Spotlight Awards
