08-30-2019 01:35 PM - edited 07-05-2021 10:55 AM
Hi guys, i recently installed a 851W to improve my wireless signal, but the thing is im next to my cisco device and the signal is allways at half... and i have my old gateway with integrated wifi that is giving me a stronger signal and its a lot of meters away... im using 802.1g and here is my related config... what can i do to improve?
I also find out after a while im connected to the wifi it gets disconnected and connects again... i got this log message from my router every time
Not encrypted dot1x packet from 1c56.fee6.ded5 has been discarded
*Mar 1 00:55:29.395: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1c56.fee6.ded5 Reason: Previous authentication no longer valid SSID[851W]
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid 851W
speed basic-54.0
station-role root access-point
infrastructure-client
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
08-30-2019 02:11 PM
"Hi guys, i recently installed a 851W to improve my wireless signal, but the thing is im next to my cisco device and the signal is always at half... and i have my old gateway with integrated wifi that is giving me a stronger signal and its a lot of meters away"
What is really important is your client capability. Getting a strong signal does not mean it is always good, that's why we do not power AP to its max power level. Even if you get a good signal from meters away , does your client has capability to transmit that far ?
What client do you have ? Do you know what power level Cisco AP operates ?
Rasika
*** Pls rate all useful responses ***
08-30-2019 02:20 PM
08-30-2019 04:00 PM
I noticed configuration got TKIP enabled, which means you can't get any 802.11n/802.11ac data rates. I would suggest you to enable AES encryption on this SSID which will allow you higher speeds (> 54Mbps)
Rasika
08-31-2019 10:07 AM
08-31-2019 02:49 PM
Does it only got Radio 0 band (2.4GHz) ? If you looking for higher throughput you should consider having 5GHz capable AP.
Anyway, post "show dot11 associations <client_mac_address>" output from your AP.
Rasika
08-31-2019 07:32 PM
09-02-2019 04:47 AM
You have both antennas correctly attached?
Can you try the commands (not sure if they are correct):
power local cck max
power local OFDM max
09-04-2019 07:15 PM
Yeah i already try those commands but its the same... and it has only one antenna... not two..
09-05-2019 12:01 AM
09-05-2019 09:02 AM
09-05-2019 10:42 PM
