Low signal and disconnect issue with 851W
Hi guys, i recently installed a 851W to improve my wireless signal, but the thing is im next to my cisco device and the signal is allways at half... and i have my old gateway with integrated wifi that is giving me a stronger signal and its a lot of meters away... im using 802.1g and here is my related config... what can i do to improve?
I also find out after a while im connected to the wifi it gets disconnected and connects again... i got this log message from my router every time
Not encrypted dot1x packet from 1c56.fee6.ded5 has been discarded
*Mar 1 00:55:29.395: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 1c56.fee6.ded5 Reason: Previous authentication no longer valid SSID[851W]
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid 851W
speed basic-54.0
station-role root access-point
infrastructure-client
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
11 Replies 11
"Hi guys, i recently installed a 851W to improve my wireless signal, but the thing is im next to my cisco device and the signal is always at half... and i have my old gateway with integrated wifi that is giving me a stronger signal and its a lot of meters away"
What is really important is your client capability. Getting a strong signal does not mean it is always good, that's why we do not power AP to its max power level. Even if you get a good signal from meters away , does your client has capability to transmit that far ?
What client do you have ? Do you know what power level Cisco AP operates ?
Rasika
*** Pls rate all useful responses ***
Its currently operating at 54 (802.11g) and the clients are basically everything! my motoral cellphone, my computer with a wireless adapater and everything else
I noticed configuration got TKIP enabled, which means you can't get any 802.11n/802.11ac data rates. I would suggest you to enable AES encryption on this SSID which will allow you higher speeds (> 54Mbps)
Rasika
I changed to encryption mode ciphers aes-ccm and i still get low signal ... this is my current config
no ip address
beacon period 20
ssid CISCO
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 15
power local ofdm 15
power client 18
packet retries 128
channel 2437
no cdp enable
bridge-group 1
dot11 ssid CISCO
vlan 1
authentication open
guest-mode
wpa-psk ascii 0 internet
no cdp enable
bridge-group 1
Does it only got Radio 0 band (2.4GHz) ? If you looking for higher throughput you should consider having 5GHz capable AP.
Anyway, post "show dot11 associations <client_mac_address>" output from your AP.
Rasika
Why is that show command relevant?? I only have my cellphone connected to it, i dont know why it could be relevant... but here is anyway.. and yes, it only supports 2.4 i only have radio 0.. Thank you !!
802.11 Client Stations on Dot11Radio0:
SSID [CISCO] :
MAC Address IP address Device Name Parent State
1c56.fee6.ded5 10.1.1.100 unknown - self Assoc
You have both antennas correctly attached?
Can you try the commands (not sure if they are correct):
power local cck max
power local OFDM max
Yeah i already try those commands but its the same... and it has only one antenna... not two..
You're right, I found now pictures of this model with just one antenna port.
How are the transfer speeds, if you test with a wired and a wireless client using the utility iperf?
Maybe it's just a visual error and not affecting the speed.
If im next to the router i have good speed but i literally have to be next to it, and the signal is not always full... i do 10 steps and the signal goes away... its really weak, i guess its a config issue because i do a erase startupconfig after i bought it and now i have this issues... i really dont know what could be, it was working well after that
Try setting the following commands to max:
power local cck max
power local ofdm max
This is basically all you can do.
You can also try to remove the command
no power client 18
And set the beacon period to default (in case you changed it yourself to 20).
Anyway, this is such an old model, only supporting 802.11g, that I recommend that you get some newer accesspoint (you can keep using it as a slow router) with 802.11n or better 802.11ac. They also have much better reach.
