LSC sertificate issue on WLC
RDavidov
Greetings
I`m trying to configure LSC on WLC, everything goes OK before the moment when AP tries to establish DTLS connection with WLC.
Output from AP:
CAPWAP State: DTLS Setup
dtls_disconnect: ERROR shutting down dtls connection ...
CAPWAP State: DTLS Teardown
Debug from WLC indicates that problem is with issuer certificate:
sshpmGetCID: Found matching CA cert othSslLscCaCert in row 12
Found CID **** for certname othSslLscCaCert
CACertTable: Found matching CID othSslLscCaCert in row 12 x509 ****
Verify User Certificate: X509 Cert Verification return code: 0
Verify User Certificate: X509 Cert Verification result text: unable to get issuer certificate
Verify User Certificate: Error in X509 Cert Verification at 1 depth: unable to get issuer certificate
X509 OpenSSL Errors...
NONE
OpenSSL Get Issuer Handles: Cert issuer unknown; bailing ...
Certificate verification - failed!
In this document there is an interesting paragraph in which the joining process is described:
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/110141-loc-sig-cert.html
Both the LSC CA and the LAP Device certificates are installed into the LAP, and the system self-reboots. The next time it comes up, since it is configured to use LSCs, the AP sends the LSC Device Certificate to the Controller as part of the JOIN Request. As part of the JOIN Response, the controller sends its new Device certificate and also validates the inbound LAP certificate with the new CA Root Certificate.
The question is: how can I upload CA Root Certificate to WLC controller ?
Many thanks
Raul
6 Replies 6
Ric Beeching
Level 7
Level 7
The LSC certificates on the AP, have you installed those and are they from your PKI infrastructure that you intend to use with the WLC?
Normally you would install the CA certificate on the WLC (or point towards the url for the CA server) which would then facilitate issuing the certificates to the APs. Have you done it in this order or are you just trying to authenticate using LSC straight off the bat?
Please rate helpful / correct posts
Yes, I have Root CA and Sub CA sha2 in infrastructure on Windows 2016 server. On WLC I specified URL, CA and Device certificates was added also. After provisioning AP is rebooting:
Reset Request from Controller(LSC enabled) and after boot AP cannot connect to controller.
Can you do a show certificate lsc summary and show certificate lsc ap-provision on the WLC?
Is it possible the whole chain isn't included in the WLC device cert? Unlikely but just checking..
Ric
Is it possible the whole chain isn't included in the WLC device cert? - how can I check this ?
(Cisco Controller) >show certificate lsc summary
LSC Enabled...................................... Yes
LSC CA-Server.................................... http://1.1.1.1/certsrv/mscep/mscep.dll
LSC AP-Provisioning.............................. Yes
    Provision-List............................... Not Configured
    LSC Revert Count in AP reboots............... 3
LSC Params:
    Country...................................... ***
    State........................................ ***
    City......................................... ***
    Orgn......................................... ***
    Dept......................................... ITI
    Email........................................ ***@***.**
    KeySize...................................... 2048
LSC Certs:
    CA Cert...................................... Present
    RA Cert...................................... Not Configured
    DEV Cert..................................... Present
(Cisco Controller) >show certificate lsc ap-provision
Provision-List................................... Present
Idx   Mac Address
 1    00:27:e3:81:00:00
 2    00:27:e3:81:11:11
Everything looks ok but I don't have extensive experience with LSC. To confirm:
-Setup LSC
-Joined the AP to the WLC as normal
-Provisioned the AP with LSC certificates
-Restarted AP and ensured "Accept Local Significant Certificates (LSC) is enabled
- Encountered this issue
Perhaps some of the others may have more suggestions on this but I am following the same logic as you.. the WLC does not have the same Root CA cert as the AP is presenting.
Ric
Hi, can you please tell me, how you added the device certificate?
Greetings
Gordon
