02-23-2019 01:07 AM - edited 07-05-2021 09:55 AM
Hello all,
Actually I have one client facing guest portal issue. When he creat a user to use for guest, after creating first he have to suspend the user and again creat the user then he can use only. Why this happen plz let me know
02-24-2019 06:32 PM
Are you using ISE for the captive portal or the WLC?
LWA and CWA are two different styles of wireless guess
When you say they first create the user and then have to suspend the user and create again, where are you referring to this happening?
Are the users getting sent to the captive portal ok?
02-24-2019 08:36 PM
Yes using ISE here. Client using sponsor portal to creat guest user . After that suspend on sponsor portal and creat again
02-24-2019 08:45 PM
So the Sponsor is creating the account, are they setting the expiry dates correct? Make sure they are keeping in mind the timezone of ISE.
If the client is creating it, the sponsor will need to approve it before its usable.
I would be raising a TAC case as if created correctly this doesn't sound like normal operations
02-24-2019 10:08 PM
Make sure they are keeping in mind the timezone of ISE.---- you mean to say if this is different it would be issue ?
But why after suspend and creat again it works.?
