1198
Frequent Contributor
MAC address + WPA, WEP for securing wireless connection
I have Cisco 1602e AP. Currently I have configured the AP to allow access only when the MAC address matches. However the SSID shows as unsecured but doesn't allow anonymous users to connect since it allows only when the MAC address matches as mentioned earlier. I have not enabled any security key or security settings (WEP, WPA etc) . I feel it is a risk, can you suggest how to enable securitysettings without having a security key configured but with existing MAC address methods I have in place?
I tried adding " encryption vlan 30 mode ciphers tkip" under "Dot11radio 0" interface but it asking me to enter the security key on my laptop to connect wifi.
current configuration
aaa authentication login mac_methods local
aaa authentication login eap_methods group rad_eap
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
dot11 vlan-name TEST vlan 30
dot11 ssid TEST
   vlan 30
   authentication open mac-address mac_methods
   mbssid guest-mode
   information-element ssidl advertisement
username 123456790ab password 0 123456790ab
username 123456790ab autocommand exit
interface Dot11Radio0
no ip address
no ip route-cache
ssid TEST
antenna gain 0
stbc
beamform ofdm
mbssid
station-role root
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 spanning-disabled
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
6 REPLIES 6
VIP Mentor
Check it out
Here is the procedue to configure MAC filtering:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c1e40b.shtml
Dont forget to rate helpful posts
Hall of Fame Master
Since you already have mac filtering in place,
"can you suggest how to enable security settings without having a security key configured but with existing MAC address methods I have in place?"
There isn't a way... with WEP/WPA-Personal/WPA2-Personal/WPA-Enterprise/WPA2-Enterprise, your users will get prompted for the key or credentials if using Enterprise which is 802.1x.  Mac filter isn't a good security method, but if this is for guest users, there isn't much you can do with a stand alone access point.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Thanks for the advice. This means I have to set the security setting
with Key in addition to the existing MAC filter as a best method.
Please correct me if my understanding is correct.
Hall of Fame Master
I wouldn't use mac filtering at all... its the worse to use for securing your wireless.  look at WPA2/AES PSK which on some devices is WPA2-Personal.  For better security, you would use 802.1x, but you need a radius server and that would tie back to Active Directory.  If this is for guest users, well you don't really care about security, because you don't want to be supporting them.  If you have no choice and they are guest but you want to only allow some and not just anyone, you can use WPA2-Personal and change the preshared key once a week or what ever you decide.
Scott
-Scott
Purpose of using the MAC filtering is to avoid unathurized users connecting their personal devices or laptops in office network, unlike the PSK where the users will know the PSK and simply connect their own devices, hence the MAC filtering is in place currently.
Now I learnt that having PSK with WPA2/ES in addition to existing MAC filter is more esecure, I will go head and configure them and then will share my feedback.
Hall of Fame Master
Re: MAC address + WPA, WEP for securing wireless connection
MAC address is easy to capture with free tools and then you can spoof your device. Most secure networks will not use Mac filtering but will use 802.1x.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
