MAC Filtering via remote Cisco ACS
shanemoss
Hi folks,
We're using MAC Filtering as part of securing access to a WLAN.  A problem we're facing is the database size on the wireless controllers which is a maximum of 2048 entries.  I want to use our Cisco ACS as a centralised database to overcome this limitation, I understand that this should be possible but am having some difficulty implementing it.  Has anyone done this?  Do you know of any configuration guides for both the controllers/WCS and the ACS?
Many thanks in advance,
Shane.
George Stefanick
Hi there
Here you go
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml
George Stefanick
Hi there
Here you go
Thanks George! I couldn't find this anywhere...
