10-08-2019 07:33 PM - edited 07-05-2021 11:06 AM
I need to give a user access for just adding and deleting mac address in the controller local database. Is it possible to create a management user access with that granular level. or any workaround.
10-09-2019 12:13 AM
yes, you can have role-based access control, depends on what kind of AAA system are you using to make more granular commands that need to give to the user.
with ACS / ISE can be possible.
10-09-2019 08:54 PM
@balaji.bandi - I thought so too, but when you look at the possible roles that can be returned to a Cisco AirOS WLC, there doesn't appear to be much granularity involved.
Or am I doing something wrong?
10-09-2019 10:18 PM - edited 10-09-2019 10:18 PM
As per my knowledge you can only give access to TABs which are there in WLC GUI:
example: Monitor, WLANs, Controller.....etc
Dont forget to rate helpful posts
