Community Live- Understanding How Multicast Works with Cisco
193
management user access
I need to give a user access for just adding and deleting mac address in the controller local database. Is it possible to create a management user access with that granular level. or any workaround.
3 REPLIES 3
VIP Advisor
Re: management user access
yes, you can have role-based access control, depends on what kind of AAA system are you using to make more granular commands that need to give to the user.
with ACS / ISE can be possible.
BB
*** Rate All Helpful Responses ***
Highlighted
VIP Advocate
@balaji.bandi - I thought so too, but when you look at the possible roles that can be returned to a Cisco AirOS WLC, there doesn't appear to be much granularity involved.
Or am I doing something wrong?
VIP Mentor
As per my knowledge you can only give access to TABs which are there in WLC GUI:
example: Monitor, WLANs, Controller.....etc
Dont forget to rate helpful posts
Content for Community-Ad
August's Community Spotlight Awards
