03-21-2012 10:51 AM - edited 07-03-2021 09:50 PM
Anyone could let me know the answer to the following questions?
1. If I create the Guest user account on WCS or WLC locally, what the maximum number of guest account is allowed on WCS and WLC respectively?
2. If we have guest user account created on both WCS and WLC, will the authentication check local user DB on both WCS and WLC? If yes, WCS first or WLC first?
Thanks a lot for your help.
Solved! Go to Solution.
03-21-2012 04:26 PM
Second part first.
When you create the account on the WCS it gets pushed ti the WLC. So only the WLC db gets checked.
As for how many, that depends. The max you could have is 2048 the max db size. But Mac filters, excluded clients and IIRC interface count all take away.
You can do a show database summary and see what is taking up space in there.
Steve
03-22-2012 08:52 AM
You can adjust that to 2048 via the gui or cli... requires a reboot.
config database size 2048
03-21-2012 04:26 PM
Second part first.
Steve
03-22-2012 08:51 AM
Hi Steve,
Thanks a lot for your answer.
Here is the output of "show database summary", does it mean that our WLC can only have 512 entries in DB?
We have AIR-WLC4404-100-K9 running code 7.0.116.0
Thanks a lot.
-Kevin
Maximum Database Entries......................... 512
Maximum Database Entries On Next Reboot.......... 512
Database Contents
MAC Filter Entries........................... 0
Exclusion List Entries....................... 1
AP Authorization List Entries................ 0
Management Users............................. 5
Local Network Users.......................... 184
Local Users.............................. 1
Guest Users.............................. 183
Total........................................ 190
03-22-2012 08:52 AM
03-22-2012 09:07 AM
