1308
Rising star
Maximum number of Guest user account on WCS and WLC
Anyone could let me know the answer to the following questions?
1. If I create the Guest user account on WCS or WLC locally, what the maximum number of guest account is allowed on WCS and WLC respectively?
2. If we have guest user account created on both WCS and WLC, will the authentication check local user DB on both WCS and WLC? If yes, WCS first or WLC first?
Thanks a lot for your help.
2 ACCEPTED SOLUTIONS
Re: Maximum number of Guest user account on WCS and WLC
Second part first.
When you create the account on the WCS it gets pushed ti the WLC. So only the WLC db gets checked.
As for how many, that depends. The max you could have is 2048 the max db size. But Mac filters, excluded clients and IIRC interface count all take away.
You can do a show database summary and see what is taking up space in there.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Master
You can adjust that to 2048 via the gui or cli... requires a reboot.
config database size 2048
-Scott
4 REPLIES 4
Second part first.
Steve
Highlighted
Rising star
Hi Steve,
Thanks a lot for your answer.
Here is the output of "show database summary", does it mean that our WLC can only have 512 entries in DB?
We have AIR-WLC4404-100-K9 running code 7.0.116.0
Thanks a lot.
-Kevin
Maximum Database Entries......................... 512
Maximum Database Entries On Next Reboot.......... 512
                                                     Database Contents
    MAC Filter Entries........................... 0
    Exclusion List Entries....................... 1
    AP Authorization List Entries................ 0
    Management Users............................. 5
    Local Network Users.......................... 184
        Local Users.............................. 1
        Guest Users.............................. 183
    Total........................................ 190
Hall of Fame Master
-Scott
Rising star
Content for Community-Ad
July's Community Spotlight Awards
