Beginner
MFP in 7.0.98
Hey All,
Did anyone notice the switch for en/disabling MFP v1 per WLAN and per AP are taken out in 7.0.98? even it still shows in the help, but I can't find in the GUI interface any more. On the 'advanced' tab for WLAN, the client MFP settings is still there, but infrasutructure MFP is gone. could anyone tell me why if you know it?
3 REPLIES 3
Highlighted
Beginner
MFP in 7.0.98
Hi Sundell,
Infra MFP is no longer configurable on per wlan/AP. You can still configure it globly.
command - config wps mfp infrastructure enable/disable.
Plz do not forget to rate useful post.
Highlighted
Beginner
MFP in 7.0.98
hkumarsh,
I believe I have found this like I said, I was actually looking for a good reason why Cisco is doing so and the supported documents, I appreciate your comments if you know this.
THanks
Highlighted
Beginner
MFP in 7.0.98
coz it was causing crash and to increase the scalibility of MFP as well. Now wlan and AP mfp config is sync with globle config.
Content for Community-Ad
August's Community Spotlight Awards
