09-16-2019 05:31 AM - edited 07-05-2021 11:00 AM
I am trying to add MSE to prime 3.2 in FIPS mode and get the error enclosed. I am following cisco documentation, enabled remote account and cisco gave passphrase but it just does not work.
Any help is appreciated.
09-16-2019 06:30 AM
The message looks pretty clear. The credentials are wrong.
-If I helped you somehow, please, rate it as useful.-
09-16-2019 11:52 AM - edited 09-16-2019 11:53 AM
Credentials are correct.
no one at Cisco seems to have a clear idea, some are saying it’s not supported in FIPS mode, some say it is, I also found few bugs with no resolution or workaround but marked as fixed (CSCve01151).
so I am still in process of finding a resolution.
01-16-2020 06:10 AM
It should be fixed in Cisco MSE Release 8.0.150.0 but my customer is still unable to login, even with default credentials.
06-05-2020 10:39 AM
Hello
After updating the MSE to version 8.0.150 the message "login failed" constantly appears in the access GUI and does not allow me to access. What should I do to fix it? I appreciate knowing your experiences with this problem. Thank you..!
08-14-2020 06:30 AM
Did you find a solution? I have an open tac right now on the same scenario
