Multiple access point with same SSID but all connections goes to only one access point
Sandeep Choudhary
I have six multiple access points with same SSID, installed within as per the site survey report.
AP Name                        AP Model
EBEAP001              AIR-LAP1242AG-E-K9
EBEAP002              AIR-LAP1242AG-E-K9
EBEAP003              AIR-LAP1242AG-E-K9
EBEAP004              AIR-LAP1242AG-E-K9
EBEAP005              AIR-LAP1242AG-E-K9
EBEAP006              AIR-LAP1242AG-E-K9
95-99% Clent connection goes to EBEAP006.
There are many clients which arv very near to AP1, AP2 and AP3.
Any thoughts on why this is happening ?
Saurav Lodh
Level 7
Level 7
The clients will always be connected to AP whose signal power is best of all, if same SSID is being broadcast!!
HI Saurav,
Agree with you but this AP 6 is too far from the clients still they are connecting with it.
AP1, AP2 and AP3 are 5-10 meter far from client.
Here si the config of AP and WLAN:
(Cisco Controller) >show ap config 802.11b EBEAP001
Cisco AP Identifier.............................. 9
Cisco AP Name.................................... EBEAP001
Country code..................................... .........xxxxxxxxx
Regulatory Domain allowed by Country............. 802.11bg:-E     802.11a:-E
AP Country code.................................. xxxxxxxxxx
AP Regulatory Domain............................. -E
Switch Port Number .............................. 1
MAC Address...................................... 68:ef:bd:e3:67:78
IP Address Configuration......................... Static IP assigned
IP Address....................................... 10.47.80.11
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 10.47.80.254
Domain...........................................
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Enabled
Ssh State........................................ Disabled
Cisco AP Location................................ Ebermannsdorf
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................ EBCWLAN1
Primary Cisco Switch IP Address.................. 10.47.80.1
Secondary Cisco Switch Name...................... EBCWLAN2
Secondary Cisco Switch IP Address................ 10.47.80.3
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 7.0.240.0
Boot  Version ................................... 12.4.13.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1242AG-E-K9
AP Image......................................... C1240-K9W8-M
IOS Version...................................... 12.4(23c)JA7
Reset Button..................................... Enabled
AP Serial Number................................. FCZ141880R6
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 12 days, 14 h 00 m 32 s
AP LWAPP Up Time................................. 1 days, 23 h 20 m 20 s
Join Date and Time............................... Tue Oct 22 09:20:02 2013
Join Taken Time.................................. 0 days, 00 h 00 m 25 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211g
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    Radio Role .................................. ACCESS
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 2
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... 00:3a:98:87:bc:40
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ xxxxxx
      First Chan Num ............................ 1
      Number Of Channels ........................ 13
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 14 dBm
      Tx Power Level 3 .......................... 11 dBm
      Tx Power Level 4 .......................... 8 dBm
      Tx Power Level 5 .......................... 5 dBm
      Tx Power Level 6 .......................... 2 dBm
      Tx Power Level 7 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Current Channel ........................... 1
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11,12,
        ......................................... 13
      TI Threshold .............................. -50
      Antenna Type............................... EXTERNAL_ANTENNA
      External Antenna Gain (in .5 dBi units).... 4
      Diversity.................................. DIVERSITY_ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 24 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
    CleanAir Management Information
        CleanAir Capable......................... No
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... BDE
Network Name (SSID).............................. BDE
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 17
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ bde
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
Power level of all APs are:
    Tx Power
