10-22-2013 04:22 AM - edited 07-04-2021 01:07 AM
I have six multiple access points with same SSID, installed within as per the site survey report.
AP Name AP Model
EBEAP001 AIR-LAP1242AG-E-K9
EBEAP002 AIR-LAP1242AG-E-K9
EBEAP003 AIR-LAP1242AG-E-K9
EBEAP004 AIR-LAP1242AG-E-K9
EBEAP005 AIR-LAP1242AG-E-K9
EBEAP006 AIR-LAP1242AG-E-K9
95-99% Clent connection goes to EBEAP006.
There are many clients which arv very near to AP1, AP2 and AP3.
Any thoughts on why this is happening ?
10-22-2013 06:50 AM
The clients will always be connected to AP whose signal power is best of all, if same SSID is being broadcast!!
10-22-2013 06:56 AM
HI Saurav,
Agree with you but this AP 6 is too far from the clients still they are connecting with it.
AP1, AP2 and AP3 are 5-10 meter far from client.
Here si the config of AP and WLAN:
(Cisco Controller) >show ap config 802.11b EBEAP001
Cisco AP Identifier.............................. 9
Cisco AP Name.................................... EBEAP001
Country code..................................... .........xxxxxxxxx
Regulatory Domain allowed by Country............. 802.11bg:-E 802.11a:-E
AP Country code.................................. xxxxxxxxxx
AP Regulatory Domain............................. -E
Switch Port Number .............................. 1
MAC Address...................................... 68:ef:bd:e3:67:78
IP Address Configuration......................... Static IP assigned
IP Address....................................... 10.47.80.11
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 10.47.80.254
Domain...........................................
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Enabled
Ssh State........................................ Disabled
Cisco AP Location................................ Ebermannsdorf
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................ EBCWLAN1
Primary Cisco Switch IP Address.................. 10.47.80.1
Secondary Cisco Switch Name...................... EBCWLAN2
Secondary Cisco Switch IP Address................ 10.47.80.3
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W Version .................................... 7.0.240.0
Boot Version ................................... 12.4.13.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1242AG-E-K9
AP Image......................................... C1240-K9W8-M
IOS Version...................................... 12.4(23c)JA7
Reset Button..................................... Enabled
AP Serial Number................................. FCZ141880R6
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 12 days, 14 h 00 m 32 s
AP LWAPP Up Time................................. 1 days, 23 h 20 m 20 s
Join Date and Time............................... Tue Oct 22 09:20:02 2013
Join Taken Time.................................. 0 days, 00 h 00 m 25 s
Attributes for Slot 0
Radio Type................................... RADIO_TYPE_80211g
Administrative State ........................ ADMIN_ENABLED
Operation State ............................. UP
Radio Role .................................. ACCESS
CellId ...................................... 0
Station Configuration
Configuration ............................. AUTOMATIC
Number Of WLANs ........................... 2
Medium Occupancy Limit .................... 100
CFP Period ................................ 4
CFP MaxDuration ........................... 60
BSSID ..................................... 00:3a:98:87:bc:40
Operation Rate Set
1000 Kilo Bits........................... MANDATORY
2000 Kilo Bits........................... MANDATORY
5500 Kilo Bits........................... MANDATORY
11000 Kilo Bits.......................... MANDATORY
6000 Kilo Bits........................... SUPPORTED
9000 Kilo Bits........................... SUPPORTED
12000 Kilo Bits.......................... SUPPORTED
18000 Kilo Bits.......................... SUPPORTED
24000 Kilo Bits.......................... SUPPORTED
36000 Kilo Bits.......................... SUPPORTED
48000 Kilo Bits.......................... SUPPORTED
54000 Kilo Bits.......................... SUPPORTED
Beacon Period ............................. 100
Fragmentation Threshold ................... 2346
Multi Domain Capability Implemented ....... TRUE
Multi Domain Capability Enabled ........... TRUE
Country String ............................ xxxxxx
First Chan Num ............................ 1
Number Of Channels ........................ 13
MAC Operation Parameters
Packet Retry Limit ........................ 64
Tx Power
Num Of Supported Power Levels ............. 7
Tx Power Level 1 .......................... 17 dBm
Tx Power Level 2 .......................... 14 dBm
Tx Power Level 3 .......................... 11 dBm
Tx Power Level 4 .......................... 8 dBm
Tx Power Level 5 .......................... 5 dBm
Tx Power Level 6 .......................... 2 dBm
Tx Power Level 7 .......................... -1 dBm
Tx Power Configuration .................... AUTOMATIC
Current Tx Power Level .................... 1
Phy OFDM parameters
Current Channel ........................... 1
Extension Channel ......................... NONE
Channel Width.............................. 20 Mhz
Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11,12,
......................................... 13
TI Threshold .............................. -50
Antenna Type............................... EXTERNAL_ANTENNA
External Antenna Gain (in .5 dBi units).... 4
Diversity.................................. DIVERSITY_ENABLED
Performance Profile Parameters
Interference threshold..................... 10 %
Noise threshold............................ -70 dBm
RF utilization threshold................... 80 %
Data-rate threshold........................ 1000000 bps
Client threshold........................... 24 clients
Coverage SNR threshold..................... 12 dB
Coverage exception level................... 25 %
Client minimum exception level............. 3 clients
Rogue Containment Information
Containment Count............................ 0
CleanAir Management Information
CleanAir Capable......................... No
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... BDE
Network Name (SSID).............................. BDE
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 17
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ bde
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Global Servers
Accounting.................................... Global Servers
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Enabled
TKIP Cipher............................. Enabled
AES Cipher.............................. Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
CCKM.................................... Disabled
FT(802.11r)............................. Disabled
FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
H-REAP Local Switching........................ Disabled
H-REAP Local Authentication................... Disabled
H-REAP Learn IP Address....................... Enabled
Client MFP.................................... Optional
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID IP Address Status
Power level of all APs are:
Tx Power
