01-26-2012 06:56 AM - edited 07-03-2021 09:27 PM
Hey,
I was wondering if anyone knew a way to create multiple lobby admin account on ACS and each account will have access to only specific WLANs on the WLC?
01-26-2012 08:41 AM
I don't know if that is possible.... There is only on role for lobby and that is role0=LOBBY. That role itself will or should I say the Lobby Admin Page even when you are not going through ACS, has all the WLANs.
01-27-2012 08:07 AM
I didn' think it was possible but It was worth asking.
Also, do you know if there is a way to login to ACS with a user account created on the local ACS? I don't mean system admin accounts, I mean users created in users and identity store.
01-27-2012 06:39 PM
So you want to create a user in ACS local DB for lobby admin or for ACS access?
01-27-2012 06:55 PM
ACS access.
01-27-2012 06:58 PM
So you don't want them to have admin access, but you want them to be able to create users local to ACS?
01-27-2012 07:04 PM
Users that access the ACS needs to be defined in the System Administration section of ACS. Users and Identity Stores are only for network or device access.
