Multiples VLAN WLC 9800 CL
stobar1101
Hello guys,
I am running into a problem in my WLC 9800 CL, I cannot pass multiple VLAN traffic, I have configured the Vswitch as a trunk and activated promiscuous mode.
Switch Port Configuration
interface Port-channel15
description ** Port-Channel to UCS-6324-A **
switchport trunk native vlan 99
switchport trunk allowed vlan 10,70,90-99,800-900
switchport mode trunk
end
interface TenGigabitEthernet3/0/2
channel-group 15 mode active
end
interface TenGigabitEthernet4/0/2
end
Attachment configuration of WLC 9800 CL
Captura de Pantalla 2019-09-24 a la(s) 16.24.38.pngCaptura de Pantalla 2019-09-24 a la(s) 16.25.29.png
Jurgens L
Level 3
Level 3
Did you test without Port-Channel?
If I tried it without Port Channel and the behavior is the same.
 I´d not add vlan 99 on the command "allowed vlan" as you added it as native.  I´d try different mode for port-channel rather than active, just to make sure.
Take a close look on the VM config. Here a detailed guide:
http://www.wifireference.com/2019/08/24/cisco-catalyst-9800-cl-deployment-guide/
-If I helped you somehow, please, rate it as useful.-
