08-09-2012 12:13 PM - edited 07-03-2021 10:30 PM
Dear all,
I'm thinking of using the NCS or an NCS HA-Cluster as cental Management for a world wide environment. I'm in Europe and having already 2 WLCs connected from china. I got already problems with a WLC Update, but that was a line problem, Because I had to install a local tfpt in CN.
I couldn't find any information in the Cisco Docs, so do one of u know if there are any best practices or guidlines for an installation I plan?
Some Ideas would be very cool..
Thanks in advance.
Sebastian
08-09-2012 03:38 PM
Can you elaborate further Sebastian?
I mean, are you planning to setup a pair of NCS?
The only gotcha which I found was the virtual hardware required. Please understand that NCS comes in two distinct flavours: physical NCS server and virtual.
With Virtual you need to be hosted in a VMware.
If you want to enable HA, you do not need to purchase the second license.
08-10-2012 02:18 AM
hey thanks for the reply. My main question was about the WLC connection to the NCS and if there are any guidlines or recommendations about the line.
anyway, I plan a HA with a vitruell applicance and I'm also thinking if that is really necessary because maybe the VM HA features are enough, I will install it on a UCS system I guess..
what do you think, is VM HA enough or a NCS HA better, Maybe I have to use a WAN linlk between the system, like I see that is not a good option...
