11416
Beginner
NCS(Prime Network Control System)Can't start DB、Can't use WEB interface access
                   HI
my ncs server is restart,but the NCS can not start  DB.AND Can't use WEB interface access.
the status:
PCQ-NCS-01/admin# ncs status
Health Monitor is running, with an error.
initHealthMonitor(): can not start DB
Reporting Server is Stopped
Ftp Server is Stopped
Database server is stopped
Tftp Server is Stopped
Matlab Server is Stopped
NMS Server is stopped.
PCQ-NCS-01/admin# ncs start
Starting Network Control System...
This may take a few minutes...
Health Monitor is already running.
Failure during Network Control System startup.  Check launchout.log for details.
the show-tech file
what  happern?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Beginner
Hailin,
Did an SSH session happen to time out while you were in the process of upgrading or performing other actions?
Hopefully you have the NCS backed up.
To get it back up and running do the following from the CLI.
1. Stop the NCS
2. Run 'ncs db reinitdb'
3. Start the NCS
***WARNING*** You may lose database information but with this you
should be able to get the NCS back up and running.
Aaron
3 REPLIES 3
Beginner
Hailin,
1. Stop the NCS
3. Start the NCS
Aaron
Beginner
Re: NCS(Prime Network Control System)Can't start DB、Can't
Hi Hailin,
I'm experiencing 100% same problem here after rebooting.
Have you resolved the issue?
Cheers
Jeong
Highlighted
Beginner
I have the same problem too.
I have the same problem too. PI version is 1.3. PI have not been working after rebooting hardware appliance. I have been receiving same message like hailin huang when I use command ncs status.
Content for Community-Ad
August's Community Spotlight Awards
