238
Beginner
NCS Virtual Disk Re-size
I wanted to know if anyone has had to increase the size of their NCS disk or if it is possible. We plan to installed the virtual appliance, but do not have the space currently for the recommended 200GBy of minimum disk space in our SANs. Can the disk size be changed in the future if we choose to give it less than the recommended amount?
Edward T. Fifer
Everyone's tags (1)
1 REPLY 1
Highlighted
Hi Edward,
The installer won't even initiate the install script before the required resources are available. In this case, for a small VM for NCS it would require atleast 200 GB space as you already found out. Unfortunately, this requirement would be regardless of whether you're doing thick or thin deployment on the VM side.
Ram.
Content for Community-Ad
August's Community Spotlight Awards
