02-25-2020 02:05 PM - edited 07-05-2021 11:46 AM
This is the first time I have needed to setup an SSID that I can push out with a PI template. All the templates were created before it was my job. I'm having trouble figuring out the difference between all the AP Groups, WLAN Configuration, etc that are all in the Features and Technologies section. The goal is to have an SSID that allows students to do eSports at a specific time on ONE AP that I can add or removed the special SSID when needed. I was able to create a WLAN Configuration by checking out an old PI tutorial and figuring out the differences. What do I need to do next ? AP Group ?
02-26-2020 05:14 AM
yes the WLAN template must exist and be known to one (or more) controller(s).
but then only AP's in the default group (not assigned to a specific group) transmit this SSID
if you want this SSID sent out by a limited numer of AP's
then you create a new AP-group with this WLAN and others if desired and also apply to the controller
then you assign this group to this access point (if you do this from the accesspint configuration)
or assign the access point to the group (if you do this from the group configuration), then apply to the controller
You do not need to remove the WLAN from the group but only disable/enable the wlan as desired from the wlan template and apply to controller
02-26-2020 06:57 AM
Pieterh,
Thanks for the over view. I was hoping for more PI specifics. I'm not clear on the roll of the WLAN configuration, the AP groups, Profiles, and Dynamic Interfaces. It seems that were I save them in the Templates area matters , since I can only see some in various screens.
02-26-2020 08:03 AM
Hi John,
you decide how you want your templates ordered for navigation.
possibly there was no attention for doing this logically,
probably you have a "my templates" branch and within my templates a "discoverd templates" branch
you will find most templates here
but you are in luck you can move templates to another point in the tree
e.g. look for a template in
Configuration / Templates / Features & Technologies
Templates / My Templates / Discovered Templates / Controller
You see an circled "i", when you hover over this you see the option to move to another folder
02-26-2020 08:32 AM
Thanks !
I was wondering how to move Templates.
I'm walking through a working SSID set of templates to see how they all relate to each other and where they are stored in the Features and Technology tree. For instance, where do templated need to be to be seen in the WLAN VLAN Mapping drop down menu and what TYPE of template does it need to be ?
02-27-2020 12:04 AM
AFAIK the place in the tree is not relevant, you can select any existing template
but a "default" place can be seen when you navigate in the tree to create a new template from a blank template
or from a blank environment you added a controller and did a "discover templates from controller"
e.g. for WLAN:
-> Templates / Features and Technologies / Controller / WLANs
or Templates / My Templates / Discovered Templates
a basic workflow would be something like
- create dynamic interface
- create wlan
- create ap group
- (add ap's to this group)
- apply templates in this order
else CPI "knows" the controller has no suitable interface for the wlan
you can streamline this by creating a configuration group
Configuration / Templates / Configuration Groups
and add templates to this group,
you can use this group to deploy templates, CPI will apply the templates in the right order
and you can use this group to audit the configuration
CPI will check if the current controller configuration matches the template and display the differences
(eg when modified local on the controller not using CPI)
For more complex configurations you can create additional template like for radius servers, ACL's radio settings, global controller settings.
