Highlighted
Beginner
no APs seen in Cisco Prime Infrastructure 3.6 with WLC 9800-CL
I have installed a fresh Cisco Prime Infrastrucutre (PI) 3.6 appliance under vmware and we dont see (Inventory / Device Management / Network Devices) the unfield access points in PI from the cisco 9800-cl wlan controller.
The only thing what we see is the wlc self, but there are two access points connected with the wlc.
also in the dashboard overview in PI is nothing to see
Does somebody has any idea?
thanks and regards,
1 ACCEPTED SOLUTION
Highlighted
So I have the solution for me.. I do an downgrade from prime from 3.6 to 3.5 and it's works.
I dont now, what the 3.6 has for problems..
5 REPLIES 5
Highlighted
Hall of Fame Master
I have not tried that version yet, but the CL is supported, but what model AP's do you have?
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/release/notes/cpi_rn.html#41764
-Scott
Highlighted
hi scott,
I have the 2802i series..
Netflow is also working..
regards
Highlighted
in prime I a have found maybe the issue.. but currently not solve..
the job " Learn Unified AP Ping Capability" in prime is not working or has a failure.. with the message "Atleast one Associated Unified AP is required to be present in the system"..
Highlighted
Highlighted
Beginner
9800-CL works via netconf-yang, I applied it as an explanation of the link and it worked:
https://www.cisco.com/c/pt_br/support/docs/storage-networking/management/200933-YANG-NETCONF-Configuration-Validation.html
validation:
Prime_Infrastructure# ssh <9800_ip_address_added_to_primeinfra> <priv15_username> port 830
Content for Community-Ad
