09-24-2012 08:53 AM - edited 07-03-2021 10:42 PM
I have one AP which can't join WLC while other APs are on the WLC. It's on the network, it also gets an IP address from DHCP. I can ping it from my desk and also the WLC can. Is there any way to trouble shoot this issue? Thanks.
09-24-2012 09:16 AM
Sounds like a join issue.. What are you using for joining your access points? DHCP option43, DNS, boradcast ?
__________________________________________________________________________________________
09-24-2012 10:57 AM
DNS. I have other APs joined just fine but not this one.
09-24-2012 10:59 AM
What is the AP model number, WLC model and WLC code rev you are on ? Do you have enough licenses for the ap to join ?
09-24-2012 11:08 AM
AP's model is 1131. WLC = 4402 and software version 7.0.116. I have 50 licenses and only have 20 APs up and running so far.
09-24-2012 11:13 AM
Ok, good info thanks.
Can you console into the ap and cpature what the CLI output is saying?
09-24-2012 11:22 AM
I'd assume that to console into the AP would be the same as console to the router or switch? What would you like me to capture the output of the AP?
09-24-2012 12:08 PM
Correct, just like a router/switch. CLI into the AP, turn it off and then on and capture the join process.
09-25-2012 08:22 AM
Please post the following command outputs:
WLC: sh sysinfo;
WAP: sh invent;
WAP: sh version
