05-07-2013 02:50 AM - edited 07-04-2021 12:02 AM
I wanted to add several Virtual Domains in Cisco Prime Infrastructure 1.3 (the UI allows it). But then I observe that the user can only see the first Virtual Domain (the first par alphabetical order).
Is it normal (by design), or is it a bug, or is there something that understand wrong ?
Many thanks in advance,
Best regards,
David
05-07-2013 05:06 AM
Well you can have multiple virtual domains, but a user can only belong to one virtual domain. That is what I have seen and it seems to be the same with NCS and PI.
10-17-2013 02:58 AM
A user can have multiple virtual domain assigned , but only one is active at login.
Anyway the user can change the current virtual domain using the virtual domain drop-down list at the right top of the page.
